dopedagain
Сообщение dopedagain »
Its possible to add the zmp of the apple maps to Sasplanet? the colours of apple maps are better to stop the diferent types of trees from above. Thanks in advance!
TSA
Благодарил (а): 23 раза
Сообщение TSA »
dopedagain писал(а):Its possible to add the zmp of the apple maps to Sasplanet? the colours of apple maps are better to stop the diferent types of trees from above. Thanks in advance!
yes he was like
k0twa
Сообщение k0twa »
can someone add this map please?
http://mapy.tuzvo.sk/hofm/default.aspx
k0twa писал(а):can someone add this map please?
It is probably possible but without geotagging (linking to other maps).
Here is a link to a tile:
http://mapy.tuzvo.sk/webags/rest/services/HOFM/aofm2010_v3/MapServer/tile/22/41316/39128?blankTile=false
and similar (not exactly the same) tile in Google:
https://khms3.google.com/kh/v=883&src=app&x=17944&y=11371&z=15
Tile coordinates X,Y,Z are very different.
k0twa
Сообщение k0twa »
question no1: from where or how did you get the tile?
question no2: this tile is from normal map but there is allso a old map from 1950 i need tiles from this map..i dont need whole map just some locations..
question no3: if i download tiles that i need i have to stick it toogether manualy or is there any program? i want to put the image in sonar in AT5 format
thank you
k0twa,
1. Checked in Chrome - Ctrl I
2. I guess old map has the same addressing
3. SAS Planet can stitch the tiles to produce jpeg or other image.
deniboyone
Сообщение deniboyone »
Здравствуйте, подскажите, карты с ресурса https://rgis.spb.ru/mapui/ как-нибудь можно подтянуть в sasplanet?
TSA
Сообщение TSA »
deniboyone писал(а):Здравствуйте, подскажите, карты с ресурса https://rgis.spb.ru/mapui/ как-нибудь можно подтянуть в sasplanet?
https://gs1.rgis.spb.ru/geoserver/wms?S ... 5999999999
deniboyone
Интересно, а слои можно вытянуть оттуда? (например, зоны магистральных трубопроводов или зоны сетей и сооружений связи)
rass
Благодарил (а): 61 раз
Сообщение rass »
Новость. RGIS по Московской области обновил аэрофотоснимки от 2020 года
https://rgis.mosreg.ru/v3/#/map?bbox=30 ... 4,57.82185
