hello
from SASPlanet I can export in GPX file but when I try to import the file .gpx in basecamp there is a error
do you know why ?
thanks
gilles
Impossible to import GPX file into BaseCamp
mistergiloo
Re: impossible to import in GPX file in basecamp
Of course we do. We are so good in telepathy. That's happening while u try to import the file .gpx in basecamp, and there is an error. There are no other possible reasons.mistergiloo писал(а):from SASPlanet I can export in GPX file but when I try to import the file .gpx in basecamp there is a error ?
do you know why ?
http://www.gnurou.org/writing/smartquestionsfr
#простити, не смогла удержатьсо душа поэта...мало нам братьев по разуму, не умеющих задавать технические вопросы - теперь вот еще и буржуи подтянулись...
mistergiloo
hello
I try to import this Gpx file (demoscougpx.gpx) made with SASPlanet in basecamp (old and new version on PC and on Macintosh) and I can't
because I have an error message.
thanks a lot
gilles
thanks a lot
gilles
- Вложения
- demouscougpx.gpx.zip
- gpx file
- (1.72 КБ) 283 скачивания
mistergiloo
Probably Basecamp does not like some headers or extensions in this gpx file. Can you compare it to a "valid" gpx file? You can replace all headers and/or remove some lines and try again.
You could also try to save the file in another encoding - now it's utf8, maybe basecamp only works with ANSI (just a guess).
SergeyKa
Не понимает Basecamp указанный namespace
Файл импортируется нормально только с таким заголовком
Attached file normally imported into BaseCamp.
mistergiloo
thanks
but It would be great if .GPX from sasplanet could be compatible with basecamp like .KMZ
have a nice we
gilles
have a nice we
gilles
SergeyKa
This information will be useful to developers. And also you can change the header in the GPX file in any text editor, and it will be imported correctly.
Последний раз редактировалось SergeyKa 12 мар 2016, 23:15, всего редактировалось 1 раз.
Тикет в Багтрекере нужен с конкретным предложением и обоснованием.SergeyKa писал(а):This information will be useful to developers
SergeyKa
Хм.. у меня нет обоснования и предложения. Я просто сделал файл, который корректно импортируется. Почему BaseCamp не понимает старый заголовок мне неведомо...
