500e ерроры
500e ерроры
С некоторых пор частота появления этой вот мессаги начинает не просто раздражать, а уже и напрягать даже...... :twisted: :twisted: :twisted:
HTTP Error 500.0 - Internal Server Error
C:\Program Files (x86)\Parallels\Plesk\Additional\PleskPHP5\php-cgi.exe - The FastCGI process exceeded configured activity timeout
Detailed Error Information
Module FastCgiModule
Notification ExecuteRequestHandler
Handler Plesk_Handler_0-1670304833
Error Code 0x80070102
Requested URL http://sasgis.org:80/forum/posting.php?mode=quote
Physical Path C:\inetpub\vhosts\sasgis.org\httpdocs\forum\posting.php
Logon Method Anonymous
Logon User Anonymous
Most likely causes:
* IIS received the request; however, an internal error occurred during the processing of the request. The root cause of this error depends on which module handles the request and what was happening in the worker process when this error occurred.
* IIS was not able to access the web.config file for the Web site or application. This can occur if the NTFS permissions are set incorrectly.
* IIS was not able to process configuration for the Web site or application.
* The authenticated user does not have permission to use this DLL.
* The request is mapped to a managed handler but the .NET Extensibility Feature is not installed.
Things you can try:
* Ensure that the NTFS permissions for the web.config file are correct and allow access to the Web server's machine account.
* Check the event logs to see if any additional information was logged.
* Verify the permissions for the DLL.
* Install the .NET Extensibility feature if the request is mapped to a managed handler.
* Create a tracing rule to track failed requests for this HTTP status code. For more information about creating a tracing rule for failed requests, click here.
Links and More Information This error means that there was a problem while processing the request. The request was received by the Web server, but during processing a fatal error occurred, causing the 500 error.
Re: 500e ерроры
затянувшийся хабрэффект?
http://habrahabr.ru/blogs/google/82175/
Re: 500e ерроры
точно, но уже слава богу на спад идет)
Я кстать хотел у тя спросить, но в аське не застал, какого ты мне тогда советовал хостера?
workdao
Re: 500e ерроры
Сообщение workdao »
по-моему чаще стало появляться...
не которое время вообще не было
Re: 500e ерроры
счас вроде устаканилось, вчера вечером и сегодня сутра ужос был
Re: 500e ерроры
feya писал(а):уже слава богу на спад идет)
Щас, ага. Что ни вечер - зайти вообще невозможно, не говоря уж о том что почитать\поотвечать.
Уже недели три так. Раньше тоже было, но еще как-то более-менее терпимо...:(
feya писал(а):какого ты мне тогда советовал хостера?
http://www.webhostingbuzz.com
Сколько лет уж с ними - проблем нету. Саппорт оперативный и вменяемый.
Virtual
Re: 500e ерроры
Сообщение Virtual »
мдя чтоб написать этот пост пришлось 15мин затратить. загрузка любой страници это 15...30 рефрешей при том что ответ от IIS с ош.500 приходит мгновенно, тоесть канал и центральный вэб сервер не тормозит, а вот далее.....
хостер говно срочно менять, ибо точно блочут похоже по количеству одновременных соеденений.
ЗЫ канал 4мбит ный, скорость загрузки в пределах нормы, если умудрится не словить ошибку :(.
ЗЫЗЫ за дешевыми хостерами буржуйскими не гонитесь, они все такие, есть опыт....
может agava?...не самые.... нои точно не отстой.
Virtual
Re: 500e ерроры
Сообщение Virtual »
завтра на работе гляну в каких случаях IIS с 500 отлуп дает, если не забуду :mrgreen:
мдя...
Больше всего посетителей (35) здесь было 19 фев 2009, 20:50
это-ж что такое?.... :( это-ж как все должно глючить...
Re: 500e ерроры
Вот-вот. У меня на локалхосте больше бывает - и ничего...... А я - далеко не веб-хостер, берущий за это денюжку.
Хостера - на 3 советских буквы. :twisted:
Re: 500e ерроры
Форум не пользуется популярностью)
А хостера надо менять, эт да, руки токо не дойдут...
Вернуться в «Замечания по работе сайта»
